nymphaeles
- Nov 28, 2017
- 92
- 59
Hi, Thanks for the prompt replies. I'm using a Panasonic TX-58AX802B which is a 58" UHD LED screen as my monitor. I have installed the IE plug in and the log in screen is there but again it's tiny. Tried to do a screen grab but it(Chrome) says it will not run an extension withing another extension I'm currently running the resolution at 3840x2160
If this is the only monitor hooked up to your Windows 10 PC, then use Pale Moon browser and that Web interface from the browser should give you all the tools you need to configure you cams. Within the browser interface, you can use Ctrl+ to increase your interface size, and that may help, too.
