The Automation Guy
Wired is better than wireless.
That being said, trying to install a wired system in an existing home can be extremely frustrating (and costly). Personally I decided to wire my entrance doors, glass breaks and motion detectors. I have attic access that allowed me to accomplish this wiring pretty easily. However for the windows I decided to go with wireless contacts because running wires to the window frames would have been a giant headache. The wireless system has two way communication, so it will alert you if a contact goes "offline". Also, while the wireless contacts obviously require battery power, the ones I have have lasted years without needing to be replaced.
Please note, this is with a regular "old fashion" alarm system. Personally I would not use something like Ring, Simplisafe or similar "new style" wireless system. I honestly don't know if the cloud is required with these types of systems, but those systems are based on the fact they want to collect your data. An old fashion alarm system is not designed to collect your information and I feel much more comfortable installing one of those in my house. Plus I do not want to buy hardware that is limited to a single company. If that company goes out of business, my alarm monitoring stops and the ability to expand or replace devices would become much harder as well. The "old fashion" alarm parts are widely available through countless manufacturers.
As far as monitoring, there are still several companies that you can pay to monitor your "old fashion" style alarm system, so you can shop around for what you need. You also should not have a system installed that requires you to enter into a contract for monitoring (like ADT). Those are a scam as well IMHO. "Normal" monitoring companies are much less expensive per month than something like ADT. You can also self-monitor the system if that is what you want to do.
