HI everyone,
I'm struggling with my hikvision camera network share configuration. Following the first post advice I made some initial steps:
1) Prepared dedicated .img files with ext4 filesystem and fixed size (50GB each, all located on a Ubuntu 18.04 server). Images were created according to this article
2) The images are mounted and shared in my local network (samba share with a dedicated user "cam"
3) I took care of permissions and access rights: the "cam" user owns all image files and mounted shares (owner + group) on the server, permissions are set to 774.
It looks like the user and access right is OK. As I press "Test" it creates a directory called "test" which is a confirmation of successful connection.
* camera network drive access settings:
* after I press "test"
* the directory "test" created despite the error. I'm aware that I need to remove it manually to initialize the drive.
* As mentioned the directory should be ~50GB
* but according to the camera software it's not...
* In my opinion this causes following error:
I have no idea what could went wrong between user authentication and disc initialization...
I'd appreciate your support!
