OK, I think I "MAY" have found the way to record from this intercom the way it is supposed to be, which is not a continuous pull from a solution like NAS + Surveillance Station, but a remote recording in response to a motion event detected by the unit.
I summarize my findings:
This video shows pretty much the process outlined above:
And this is where I am stuck for now: I don't see any hard drive available. I think it is because Storage Server wants at least one dedicated partition. My PC (a NUC i5) has one small 128GB SSD with only one partion for Windows, and that cannot work as Storage Server has to format the entire partition.
I believe that if you have a dedicated partition, Storage Server will see it, allow you to format it, and record in it every time the intercom send it a ping via port 8000. This is similar to the process to have other Hikvision cameras record each in its own folder in the NAS: create a folder and a user for each camera, assign a quota, and from the Hikvision camera interface format the NAS folder.
My SSD is too small and too full to create a separate partition and I cannot remotely access the house at this moment.
As a test, I tried to map in the PC a folder from the local NAS, but Storage Server does not see it, it has to be a physical local disk partition.
If anybody wants to take from here, please share your findings. I'll be able to experiment further only when I'll be able to access the house to add an SD to the NUC or replace the SSD with a larger one and create a dedicated partition in it.
- All the owners of the DS-K8003-IME intercom need to have latest iVMS4200 Client installed on a local computer to configure it as, differently from other Hikvision cameras, this intercom does not have its own web interface.
- you need in the same LAN a storage server, which can be any PC with iVMS 4200 SERVER running on it. This can be the same PC as the one where you installed the Client, in fact you can install Client and Server together. My PC is a small NUC.
- with iVMS Client, add the intercom to the devices and among the other settings make sure you configure Motion Detection and tick "Notify Surveillance Center". This makes the intercom to send some ping to port 8000 of the storage server to trigger recordings.
- on the PC, set to run automatically the Server. Beside asking for a password the first time, there is no interface and nothing to configure.
- back to iVMS Client, go again to the devices pages: you should see the storage sever running among the other cameras and intercom: add it as you would add any other Hikvision camera, using the password you used to register the server
- still from the iVMS Client, configure the server as you would configure a device. One of the option is Storage. In that you should see local hard drives available to record.
