You are welcome!Thankyou all for the easy & clear instructions.
Though I did think they were a bit on the lengthy side...
No need for brickfix540 as you don't need to downgrade the firmware from 5.4.0 or higher if you are currently running 5.2.0.Please, write, what steps do I need to perform in order to competently flash the chinese camera with a multilanguage firmware?
On my big assumption that G1 cameras are the same hardware as G0 cameras - maybe get some confirmation of someone who knows -I have G1 2xx5 Cameras can it also work with these
However don't find firmware for these cameras:
DS2CD2145F-I
What are you confused about?thanks for the answer. I'm confused((
That's not been others' experience, as far as I know.Through the Web, it was not possible to update from 5.3.0_151016 to IPC_R0_EN_STD_5.4.0_160530.
Yes, that is the first step.Do I need to downgrade to 5.2.5 via the downgrader?
