fenderman
Staff member
			- Mar 9, 2014
- 36,891
- 21,417
you can update if you are certain your cam is US region...So my takeaway here is find a reputable dealer but for no reason should I try to update the firmware.
I really want to DIY this whole project myself but it is very intimidating. Thankful for all of the knowledge everyone here has. I've locked myself in with the HikVision NVR and I think I want to use turret cameras. Just trying to find someone to buy from I feel comfortable with.you can update if you are certain your cam is US region...
This is the content of the .rar file:Okay I went there and downloaded the .rar file- But i see no place to get the tftp updater application?
alastair@PC-I5 ~/tmp $ ll
total 19748
drwxr-xr-x  2 alastair alastair     4096 Sep 20 11:07 ./
drwxr-xr-x 49 alastair alastair     4096 Sep 18 21:16 ../
-rw-r--r--  1 alastair alastair 19819598 Jun 17  2015 digicap.dav
-rw-r--r--  1 alastair alastair      509 Jun 17  2015 How to upgrade.txt
-rw-r--r--  1 alastair alastair    28672 Dec  7  2007 tftprc_en.dll
-rw-r--r--  1 alastair alastair   245760 Dec  4  2007 tftpserv.exe
-rw-r--r--  1 alastair alastair       24 Dec  7  2007 tftpserv.ini
-rw-r--r--  1 alastair alastair    41164 Jun 11  2015 tftpserv.log
	The process does work better when the PC and camera are not directly wired together.But, unlike the Hikvision instructions, just have the PC and camera wired as normal to the router or switch, not directly connected.
They certainly did - removed support for SSL, now requires TLS.Did gmail change something that would cause this?
