motion is an issue even without running. Hopefully this can be tweaked with some settings a bit.
here you go
I set exposure to 1/30
second clip is with wdr on
3rd is dahua (also limited to 33.33ms)
a phone photo just to demonstrate the light level
here you go
Was this with the white LED on?
It will turn on the leds when in darkness. I did not test it yetHow was the cam during total darkness?
Wow just wow, if the time is correct that's like almost midnight. This cam is next level.leds off. I think it was in auto but it was bright enough for the cam.
Hello, I have a bit of light outside I e porch light etc but my Lorex at 1/60 or above goes into black and white, at what setting do these give up and go into black and white please ?. would consider getting s 4mm version as soon as available if can do 1/60 or 1/120 in colour without s pixelated mess
Rain has stopped and time to get the ladders out I think!
Hi ljw2k
It will be tempting to ask you add one of these to the DS-2DE3A400BW-DE(F1)(S5) that I’m looking forward to you being able to order for me.
Kindest
Dave
View attachment 80867View attachment 80868View attachment 80869View attachment 80870View attachment 80871View attachment 80872View attachment 80873View attachment 80874
This will always stay in color mode there is no B&W. This really depends for your situation but you would need a good amount of outside light to do 1/120 or use built-in light for up close coverage. In my testing I found results pretty good with a single street light and side garage lights. Actually for my particular scenario I was quite impressed with it because it certainly outperforms my new Hikvision non ColorVu G2s.Hello, I have a bit of light outside I e porch light etc but my Lorex at 1/60 or above goes into black and white, at what setting do these give up and go into black and white please ?. would consider getting s 4mm version as soon as available if can do 1/60 or 1/120 in colour without s pixelated mess![]()
Here we go a night time picture most default WDR 15 and 1/150 shutter
Comparison with the 4k Dahua camera this new Hikvision is replacing.
