ljw2k
That looks perfect for that view and just a shame about the tree. Looks much sharper for some reason than the older location.
It looks good and is that with the White LED light ON as I find Off is better for my location in fact looks as good as your 8mp 4k PTZ
You must have taken the screen shot when the LED was on after what ever settings you had done as I can see it is reflecting from the roof especially the street sign across the road and the cars rear reflectors. .
You on the firmware 5.5.150 or 5.5.160?
Either settings will look good and lets see the capture from your new 4mm as the 6mm looks perfect.
Wow that looks much better than the Hikvision ever did and I would be happy as punch with that capture from that location.
5442 Series is working very goodHere is the old location where the 6mm version was located. I did not think it was a good fit for the Hikvision 6MM camera and installed a Dahua 5442-Z4E in its place. Here is a current snapshot at night in the old location with the Dahua camera. There is a street light just to the right of the picture.
OK, I just finished mounting the 4MM version of this camera overlooking my cars. I can also see if the garage door is open.So far so good. I will post a picture this evening for a night time shot. I should not have the glare problem from the security lights that the other camera had which you can see in the picture on the beam at the end of the garage. It is the bottom one and I will be taking it down shortly.
How far is the camera to the nearest car in the picture?
I’m looking to buy the 4mm too but hesitating as the spec says the depth of focus is from 7m to infinity for the 4mm which I thought to be quite far for my usage
7' 6" to the closest windshield spray nozzle (black bump). I have to disagree with the specs, as 7M is a little over 21 feet in my book. You can see that the details on the Ford are quite clear.
Yeah it looked pretty sharp at that distance which is way closer than 7m.
