Hello everyone, I have a problem with NVR Hikvision DS-7608NI-K2/8P, new never operated, it does not start, no beeps, it is not seen on the net, following the forum I equipped myself with the material, it happened that by detaching the interface TTL NVR starts with beep, I connect to TV and configure, I notice that it gave configuration problems such as changing the clock was not possible and other abnormal things, I download the latest firmware and upgrade, then I reset the NVR and configure again. The problem is when I turn it off it doesn't start anymore, black screen, I noticed that with PUTTY it says it can't find files to start and goes into a loop. Another thing is that NVR is not seen on the network with ip 192.0.0.64 as if Hikvision has excluded TFTP procedure. I thank in advance who can help me, if possible to program NVR via serial.
