Jack B Nimble
Pulling my weight
Hiks are definately difficult to find on Ali only a 12mm turret left that I could find o well good while it lasted and time will tell if its permannent.
 stay away from that type of bullet camera....And what about this cam:
Oem ds 2cd2042wd i (4mm) hikvision engels versie ip camera 4mp security camera poe onvif netwerk camera p2p cctv ip67 h264 hik in HIKVISION DS-2CD2142FWD-IS(2.8mm) Original English version IP camera 4MP IPC Security Camera POE H265 CCTV camera O van Bewakingscamera's op AliExpress.com | Alibaba Groep
It says the firmware is upgradable and Multi language?
Look at a turret design...there are better options from dahua at this point...for best low light look at the dahua turret varifocal starlight thread $170...if you want a cheaper camera but with inferior low light perforamce to the starlight, look at this Aliexpress.com : Buy DAHUA 3MP HD WDR Network Small IR CCTV 2.7mm~12mm motorized lens without Logo IPC HDW2320R ZS new model for IPC HDW4300C from Reliable motorized lens suppliers on Empire Technology Co., Ltd
Both will be much better than the hikvision bullet.
No, turret over dome-dome is the worst design you can use... right now the best low light performer is the dahua starlight turret...will cost a bit more but worth it...whether or not it will play nice with the hikvision nvr is a different story...so you would recommend 2342 dome over 2042 turret? I bought the DS-7608NI-E2/8P NVR already, in the process of getting cameras. This is for residential use, with about 6 cameras, and 2 of those would be completely outdoor, exposed. Thanks.
