I'm looking at a HIK/OEM NVR (Winic AR304/4) and trying to gain access to reset it and re-install.
SADP shows current FW version at 3.3.2 (but as this is from Winic, not sure that correlates to HIK versions?)
from serial number, build date appears to be 2016/01/21, so not terribly old.
Trying to use the reset tool at Hikvision Password Reset Tool
but SADP 3.0.0.2 does not offer the described 'serialcode' or 'securty code' input to enter.
Clicking 'forgot password' in SADP brings up the newer import/export page for contacting hik support...
Tried older SADP 2.2.3 from hik's older versions page, but no luck there either.
Also tried the executable in the uopdate to first post, but get '404 not found' when trying to 'get user list' on http 81),
and it just times out when try httpS/SSL (to port 9010)
Any ideas how to reset this thing? NVR's are new to me as I generally use BI. (cams I have deelt with...)
thanx, Paul.
thanx, Paul.
