The problem with the anti-flicker option is it also then eliminates some parameters that you can set as it forces the camera to not allow the user to change a parameter that can bring the flicker back.
Anti-flicker does not allow a shutter speed faster than 1/100, nor does it allow the user to give the shutter speed a range, and does not allow a user to turn on WDR. It may take away others as well, but I know those two for sure.
The problem can be solved with a shutter speed adjustment, which is what I recommend so that a user maintains full ability to adjust camera parameters.
You want to stay off shutters that are whole number divisible by 50 or 60 (depending if you are in a 50 or 60hz area). So you try and odd shutter speed like 1/87 (11.49ms) or 1/66 (15.15ms), etc.
My floodlights are LED. I get a bit of that flicker/rolling wave running a faster shutter. I live with it. I am not making Hollywood movies - I want a clean capture of the perp. The rolling wave or LED flicker isn't going to impact my ability to get a clean capture of a perp, but running a slower shutter so that I don't see that rolling/flicker phenomenon will. I would rather have the faster shutter and a little LED flicker/wave.
