I founded on Dahua site a firmware that I loaded into 2 of my 4 cams SD1A404XB-GNR.
Here is the version : 2.810.0000017.0.R,2020-11-23
The readme.txt is "all version", so i tried it…. and all is working fine !
My NVR : DHI-NVR4108HS-8P-4KS2
It's firmware : V4.001.0000005.1, Date version: 26/11/2020
Oh sorry...I too have a IPC-HFW5241E-Z12E from Andy with firmware V2.800.0000000.20.R, Build Date: 2020-09-03. Got error trying to load the firmware "DH_SD-Prometheus_MultiLang_NP_Stream3_V2.810.0000017.0.R.201123".
Found newer firmware in another thread: IPC-T5442T-ZE IPC-T5442TM-AS latest new firmware General_IPC-HX5XXX-Volt_MultiLang_NP_Stream3_V2.800.15OG004.0.R.201203
Here is the link for the firmware I talked about :
Firmware OK for SD1A404XB-GNR cam
The name is "DH_SD-Prometheus_MultiLang_NP_Stream3_V2.810.0000017.0.R.201123"
This problem exists since 2017. It is very visible in slow paning. I had to patch it remove the problem as Dahua dont gives a s.....There's a new international/english version of the firmware for the DH-SD59225U-HNI with a build date of 2021-02-03
The video seems smeary when panning fast (which it didn't do with the 2017 firmware that was on this cam before), but so far lots of improvements.
Also upgrading will not give a way back as secuity level is incresed from 1.4 to 2.0 and firmware is encrypted.
Where can I download this firmware for this camera DH-SD59225U-HNI ? And how do I upload this firmware ?
NP and PN what that means ??
Thanks
hi have you find this driver ?I don't know where you can get it on the internet. Dahua pulled firmware from their public facing site. Here's the name you're looking for if you NEED it, build date shows it was just released last month:
General_SD-Eos_MultiLang_PN_Stream3_V2.810.0000000.13.R.210203.bin
The readme says:
Supported Devices:
CA-HZX0XXU-NORMAL,SD6CXXFA-GN,CA-HZX0XXDU,CA-HZX0XXTU
And I was concerned that there were no SD59xxx listed, so I had them double check and they said Dahua confirmed that was the correct firmware for the DH-SD59225U-HNI. Honestly, though, if you have the firmware from 2016 and early 2017, the video quality at night when panning is MUCH better on those early versions - keep what you have. The auto-tracking (which is what I wanted) is really crappy and not worth losing the pristene video of early 2017 builds.
could you upload files to TransferXL - Transfer Large Files Easy, Fast, Securely and Free! is free.I have it, but I don't know where you can get it on the internet. Is there a place to post it here? It's like 42MB.
have you megaupload ou dropbox count ?I have it, but I don't know where you can get it on the internet. Is there a place to post it here? It's like 42MB.
Nope, I don't use any of those.have you megaupload ou dropbox count ?
