I've been reading this forum for a few weeks (more questions later I'm sure) and I set up (maybe successfully) a dual NIC machine using a USB ethernet adapter.
But I think a couple of more pictures may make things easier and I'm confused about one setting.
After I enter the TCP properties (192.168.55.10) in the example, I go to advance and enter: 192.168.1.50.  Where does the 192.168.1.50 comes from, is that the IP address of the machine with the 2 NICs on it or is it an IP address I should never use?
And here's the picture that should be added after that showing the default gateway was set.  Could this have been accomplished without adding the "advanced" box step by just filling in the default gateway box?
And when I go back to the network settings page things look like this:
My second NIC is an "Unidentified Network".  Is that correct and or should it be changed somehow>
Thank you!
