I like pink
- Mar 2, 2018
- 34
- 19
plugged in both cameras to NVR and got account locked error.... logged in with 2nd log in and it is showing up.....
 See, when you move on to your 3rd and 4th cameras now, it will be child's play.plugged in both cameras to NVR and got account locked error.... logged in with 2nd log in and it is showing up.....
Why not just black list the cams internet access from your router? Seems way easier than messing with VLANs.thus helping to keep them from being exposed to the internet
This ^^^^ works for 99% of folks.
For folks that might not be aware, there are two totally separate 'admin' accounts on the camera.
This one (in red) is the account that everyone uses when they log into the webUI (or via an app, like smartPSS).
This one (in green) is a completely different account, and it's used to access the camera via ONVIF.
Blue Iris needs the password for the 'ONVIF' admin account in order to properly Find/Inspect a camera (and configure the camera within Blue Iris).
For 99% of folks, the two separate admin accounts have the exact same password... so even if they type the password for the 'webUI' admin account into Blue Iris, it's still going to work.
But .... for the 1% of folks whose cameras got somehow borked to where the webUI 'admin' account has a different password than the 'ONVIF' admin account, ... if you put your 'webUI' admin password into Blue Iris, BI will fail to to connect to your camera using ONVIF.
When BI fails to properly connect using ONVIF, your camera will return DIFFERENT information to BI (during Find/Inspect), and BI will configure the camera *differently*, and that camera will not act like a normal 5231 in BI.
In that case, it's not as simple as going into the PTZ tab and clicking enable. I mean, you can do that, but PTZ won't work.
When BI properly connects to your camera via ONVIF, this is what the 5231 tells it:
When BI can't connect via ONVIF, this is what the camera returns to it:
Sorry for quoting all of this, but it's relevant.
I just got my first 5231 installed yesterday. Everything appears to be working except that I don't seem to be getting the ONVIF return information shown in this example.
I've verified that the ONVIF account is using the same password as the admin account (I even went through the process of changing the ONVIF password - which requires inputting the current password, which only worked if I used the 'admin' password. So I know that's not the issue.
It list the Manufacturer as "General" but does show the cam's firmware version *and* does show "Has PTZ service: /onvif/ptz_service"
But, in BI, I can see the PTZ controls at the bottom of the live image...but they're greyed-out. I've tried different options in the PTZ tab, but no luck. (Camera model ONVIF, Dahua, etc)
Firmware on the camera is: 2.622.18R
ONVIF Version: 16.12
Ideas?
I ran the plug into my house where possible and caulked. I ended up picking some gray Waterproof boxes from Lowes. The cam fits on top of the box pretty well. I drilled holes in the box at the Waterproof seam and ran wires. Closed up the box and caulked any openings.
Im actually putting the same camera and junction box on a soffit as well...is it best to place the cam at the back or front? i thought back so it wouldnt get the IR bounce back... also are you using a piece of wood above the soffit for the screws to hold in? If so what size? thanks
	My cameras are mounted flush with the soffit. The only waterproofing I used was the Ethernet connector that comes with the camera.So i would also need some kind of waterproof box within the soffits? I dont really want a junction box if possible, id rather it flush, so its either place the pvc conduit in the soffit or a waterproof box for all the wires?
never even heard of a soffit until this forum...im originally from Manchester, UK and moved over to NY. Theres a big difference with alot of things, mainly naming terminology .lol.
