The speaker is separate, example:
I use OpenHAB to send the sounds out. OpenHAB is a home automation server. I use it for pretty much everything around the house - lights, TV control, camera profiles. You can do a lot with it.
It does this if things really hit the fan:
I keep adding sounds. I have Darth Vader saying "The emperor has been expecting you!" when someone comes to the door, and some others.Scooby-doo made me laugh, lol![]()
I had a couple questions on yourZ5 setup in BI if you don't mind. My zoom setup will only zoom to the max positions when zooming out or in. I can't get an in between to stop anywhere beside full in or full out.I keep adding sounds. I have Darth Vader saying "The emperor has been expecting you!" when someone comes to the door, and some others.
Also, with the microphone you mounted with the Z5, did you have any mic audio that sounds like being in a fish tank? The audio coming thru mic into headphones on my setup has a deep sea water audio sound when listening to the outside sounds. What speaker are you using
This is what I am using below, besides the PA speaker & amp, which I just used in the image as an example of a speaker
The audio sounds kind of bad if you're using the built in noise filter, I've disabled it:
THANK YOU!...What a huge difference that made disabling Noise Filter. The watery sound has stopped and now finally is quiet clear sounding.
I also notice you have Encode as AAC which I have changed to now, but raised sampling to 48K. If that is too high, let me know.
In BI, the Audio Options, GAIN & SENSITIVITY have any effects with recording? Right now mine are set @ 72.9% & sensitivity is minimized.
I have these options also chosen:
* Webcast Audio
* Record Audio during profiles
* Trigger camera during profiles
* Use 1 second average intensity
I get steady sound with these settings with a very random 1 second no sound. Almost sounds like one file recording ends and a new one starts type of thing. Not being a sound engineer, that is my best description of the 1 second dead sound. Sure wish Dolby could be included in settings, LOL.
Example video:
Ahhhh, Then BI must be part of the problem. I also get a pulse sound also sometimes. Not all the time, but tonight I hear it. I am not running a ground on the microphone power so it can't be a loop back from the power cord ground. The sound is much better though with the filter disabled for sure. I run head phones through the USB port on the dedicated PC system, but think I will try using a speaker port if I can get them working correctly and reload drivers and see if this corrects the pulse that rears itself occasionally.I don't use BI. The sound comes in fine on the NVR & SPSS.
Where can I get junction boxes like those? Also where do I get the mics? Does sound work using POE and blue iris?This is a better day time view, Z12 on left, Z5 on right:
