So is this the update that blocks the Chinese cameras?? @Crazykiller you said your Chinese camera doesn't work properly anymore? Could you elaborate?
How do you access the cam webUI through the NVR webUI? I've wishing I could do this the whole time!I also had issues with this specific cam with NAND flash firmware in the past and won't say it's especially for Chinese domestic cameras. I also have other Chinese models (look into my signature) which are working properly. Seems only to be the -ZS cam.
For me it isn't a real big deal that IVS is not configurable for this specific cam from the NVR WebUI. Since the 2017-04 firmware it is possible to get the cams WebUI through the NVR WebUI. So i could configure IVS there if needed.
It's possible since Firmware starting from 2017-04-18. There is a link for cams which are registered in the NVR. The search function doesn't work for me right now... just try the search yourself, i did a post for this...How do you access the cam webUI through the NVR webUI? I've wishing I could do this the whole time!
Maybe not blocked, but just the cameras firmware can't updated, so can't work well with the new firmware of the NVR. This is a important thing to be careful, as i know some guys even sell Chinese NVRs, much cheaper, but i always don't recommend those cheap ones, Original english also have cheap ones too. No need to buy the cheap and can't be updated devices.It's possible since Firmware starting from 2017-04-18. There is a link for cams which are registered in the NVR. The search function doesn't work for me right now... just try the search yourself, i did a post for this...
I updated to this firmware without a factory reset and it retained all of my settings. I did need to clear my browser cache before getting back into the WebUI for it to look right though. All seems to work well and I was able to subscribe to IVS push notifications in iDMSS Plus finally. I am not getting any IVS notifications - but at least the push notification setup is not erroring anymore.This NVR52XX-4K has new firmware new version is 20170814, anyone want to download, please download here, thank you!
How about the latest firmware that's coming with the 5231R-Z now: 2.460.0000.14.R Build Date: 2017-07-20.Will post the latest new firmware on the forum, esp for those have bugs, Just let me know if need any other firmware, i have a FTP so can download anytime.
Thanks you
@Andy, is it possible to post This latest firmware for 5231r-z.
The latest I have is march 2017.
Thanks you
When looking at different products, what do the prefixes in the files mean (General_ & DH_)? Also in the middle of the file name is either Eng or EngSpnFrn. What do these connotations mean?ftp://ftp.asm.cz/Dahua/kamerove_systemy/_Firmware/04IPC/05-Eco-savvy%203.0/DH/DH_IPC-HX5X3X-Rhea_Eng_P_Stream3_V2.460.0000.14.R.20170720/
Example: ftp://ftp.asm.cz/Dahua/kamerove_systemy/_Firmware/01NVR/01-Embedded/NVR5000-4KS2/
So Eng & EngSpnFrn is only for the system language and has nothing to do with PAL or NTSC? Is PAL & NTSC only a setting for the camera?DH is with Dahua logo in WebUI.
General is for OEM manufacturers.
Your decision if u wanna Dahua logo or not
Eng = English
EngSpnFrn = English, Spanish, French
Going through my NVR with the new firmware - I have never figured out what the IVS/Global tab was for, but on this firmware I notice I cannot select a Channel at the top to define a global area anymore. This area seems like it might be broken unless it is a browser issue for me.
