noAuto tracking?...on the SD29204S-GN?
he was talking about the SD49225T-HN which does NOT support auto-tracking
the SD49225T-HNI does tho
They make an hni version of that cam?!no
what browser are you using? is the plugin loading? I dont think you get any activity on the setup page w/out the plugin loaded
Hi Nayr, in desperate need of a new Firmware. Impossible to pull down the good firmware from the other camera I was told by an engineer they have it encrypted and password protected. I had uploaded this firmware to my cameras, the streaming is fine. But something is crashing our recordings in our server. Ever since I uploaded this firmware to a number of the bad cameras, our system went all out of wack. This is a big problem for us.This one took and fixed the zooming problem but downgraded the picture quality and interface a lot. I have attached a picture from a good cam vs the firmware just updated. At least it's good to know once we have the right firmware I think the solution will be fixed. Good one obviously has the better lighting and definition.
View attachment 14481 View attachment 14482
PTZ function works on my hikvision DS-7608NI-E2/8P but motion recording stops working if I hit any presets.Hey @nayr , any idea if the PTZ function will work on a Hikvision NVR?
Thank you for the information. What ptz are you using?PTZ function works on my hikvision DS-7608NI-E2/8P but motion recording stops working if I hit any presets.
dahui mini blackface, the one listed in the beginning of the thread. I've also used the huisun mini ptz with the nvr, ptz function works with that alsoThank you for the information. What ptz are you using?
noCan I set this camera up to automatically pan with motion on part of the screen to follow motion?
I don't think so. The tracking of sorts @nayr did was all based on external sensors and his automation system hitting the camera with commands.Can't you "sort of" do something like that with presets...say have it pan and zoom into a particular spot using a preset if motion is detected in a certain grid? I have not used one yet but I thought that was something you could do with presets....So like have a yard cam with full FOV that then pans & zooms to the front door if motion is seen in a defined area....not motion tracking but may be better than nothing.... I may be wrong about how that could work though so somebody correct me if I am.
