anthonys650
- Jun 17, 2014
- 26
- 2
Thanks the serial prompt at boot getting worse it only provide a weird hash. It’s not even complaining about finding the uboot.
How can I reflash it?
I'm trying to recover a DH-TPC-SD8620N-B50Z30. It's an expensive camera, so I've been going slow. I have a USB to TTL (CP2102 STC) adapter and I made a cable to connect GND, RX, and TX to what I believe to be the UART port. Now, I have 4 similar ports in the vicinity so I'm not sure if I'm hitting the right one. I can get 1-2 characters of garbage but not the boot verbosity as previously mentioned.
I probed the ports and found VCC and GND, and swapped TX/RD multiple times on the UART port. I don't think it's totally dead since it does a PTZ sweep when it boots and if I sniff the network interface it's on its default IP of 192.168.1.108. It responds to ping, telnet, and SSH. I do not have login credentials. Attached is a picture of the port. I added 12" pigtails (before I took this pic) so it can rotate without chewing or shorting my USB TTL converter.
What're all the ports for? Anything else I can be doing? Input appreciated!
If it is responding to the network, I would suggest going the TFTP route, the arp for 192.168.1.1 is indicative of it looking for the gateway to contact 192.168.254.254. You can run most of the serial commands though the TFTP load file and view the output in the console, and while it doesn't give a live command prompt it would be a good indication of what is wrong, even with a serial connection you likely will need a TFTP server up and running anyways to reflash.
01:35:59.654381 IP 192.168.1.108.netopia-vo3 > 192.168.254.254.tftp: 69 RRQ "upgrade_info_7db780a713a4.txt" octet timeout 1 tsize 0 blksize 1468
By console I mean the console (Ncat) that is included in the TFTP (Click the link or check page one of this thread) package on this site, it reads the output from from the camera over the network during the tftp and displays the results.
It also has the batch file needed to generate the proper upgrade_info file by running commands.bat
Based on the other thread you should be able to do a TFTP recovery by installing the firmware again over TFTP, but you can also try using telnet since that seems to be open to you, with telnet you need to add "7ujMko0" (without the quotes) before the password you used example:Hi
I came across this interesting thread, and was wondering if this method will work with this problem : DH-IPC-HDBW2300RP-Z issues
I have 6 of them showing the same symptoms, does it worth trying to recover them ?
Best Regards.
>printenv
bootargs=console=ttyS0,115200 mem=118M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc
bootcmd=sf read 0x2000000 0x1040000 0x1c0000;bootm 0x2000000
bootdelay=3
baudrate=115200
ethaddr=00:12:34:56:78:9A
ipaddr=192.168.1.108
serverip=192.168.1.1
autoload=yes
gatewayip=192.168.1.1
netmask=255.255.255.0
mp_autotest=0
ID=000000000000000000
da=tftp 0x02000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite
dr=tftp 0x02000000 romfs-x.squashfs.img; flwrite
dk=tftp 0x02000000 kernel.img; flwrite
du=tftp 0x02000000 user-x.squashfs.img; flwrite
dw=tftp 0x02000000 web-x.squashfs.img; flwrite
dp=tftp 0x02000000 partition-x.cramfs.img;flwrite
dc=tftp 0x02000000 custom-x.squashfs.img; flwrite
up=tftp 0x02000000 update.img; flwrite
tk=tftp 0x02000000 uImage; bootm
dh_keyboard=1
appauto=1
sysbackup=1
logserver=127.0.0.1
loglevel=4
autosip=192.168.254.254
autolip=192.168.1.108
autogw=192.168.1.1
autonm=255.255.255.0
pd=tftp 0x02000000 pd-x.squashfs.img; flwrite
stdin=serial
stdout=serial
stderr=serial
ethact=ambarella mac
Environment size: 1035/131068 bytes
Ncat: Version 7.40 ( https://nmap.org/ncat )
Ncat: Listening on 192.168.254.254:5002
gBootLogPtr:00b80008.
spinor flash ID is 0x1940ef
*** Warning - bad CRC, using default environment
sync..
buf no align with 8 bytes,len:0x800
Fail to write spi flash from :40000 in 0 chip.
partition file version 2
rootfstype squashfs root /dev/mtdblock5
fail to parse HWID
fail to parse bootargsParametersV2.text info
fail to init bootargsParametersV2
TEXT_BASE:01000000
Net: PHY:0x03625cc6,addr:0x01
s3l 55k+bcm54811 init
sd update init:HWID is missing!
Using ambarella mac device
Download Filename 'upgrade_info_7db780a713a4.txt'.Downloading: 100%
## file size: 202 Bytes, times: 0s, speed: 14.6 KiB/s
done
Bytes transferred = 202 (ca hex)
Download Filename 'romfs-x.squashfs.img'.Downloading: 100%
## file size: 3.2 MiB, times: 6s, speed: 474.6 KiB/s
done
Bytes transferred = 3303672 (3268f8 hex)
curVer:V1.4 <= newVer:V1.4,verCompare success!
[0;32mUBOOT_commonSwRsaVerify run successfully!
[0m
## Checking Image at 02000000 ...
Legacy image found
Image Name: romfs
Created: 2020-04-30 7:22:56 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3301376 Bytes = 3.1 MiB
Load Address: 01b80000
Entry Point: 01fd0000
Verifying Checksum ... OK
Programing start at: 0x01b80000 for romfs
SPI probe: 32768 KiB W25Q256FV at 0:1 is now current device
write : 96%__do_write_flashSpi: error!
flwrite error 1!
cmd Failed run dr!
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
cmdLine console=ttyS0,115200 mem=118M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc
U-Boot 2010.06-svn6390 (Feb 19 2020 - 12:04:41)
[QUOTE]boot[/QUOTE]
SPI probe: 32768 KiB W25Q256FV at 0:0 is now current device
Verifying Checksum ... Bad Data CRC
ERROR: can't get kernel image!
try:kload 0x2000000 fail to get partinfo
failed!
>partition
fail to uncompress
fail to load partition.txt from e0000
fail to load partition file
partition isn't exist
>bdinfo
arch_number = 0x23283041
env_t = 0x00000000
boot_params = 0x00200000
DRAM bank = 0x00000000
-> start = 0x00200000
-> size = 0x07600000
ethaddr = 00:12:34:56:78:9A
ip_addr = 192.168.1.108
baudrate = 115200 bps
If I had to try something that's where I would start (aside from programming the flash chip with an external tool)
Hi Corellon, is there a thread thread that talks about the tools required to flash a chip with an external tool? I have an issue with a camera a few pages back on this thread and I would like to try this as a last resort.
Using ambarella mac devicerun dr
Using ambarella mac devicerun dk
Using ambarella mac devicerun du
Using ambarella mac devicerun dw
Using ambarella mac devicerun dp
Using ambarella mac devicerun dc
Using ambarella mac devicetftp 0x2000000 pd-x.squashfs.img; flwrite
Using ambarella mac devicetftp 0x2000000 .FLASHING_DONE_STOP_TFTP_NOW
Wrong Image Format for bootm commandsleep 5
boot
