- it have 140 ° horizontal view at 1.3mm not 2MP, i prefer 2 MP
have good day
Iirc you need a password to change special settings. ....
No its noticed 2mp but in relaity is 1.3 MP max, maybe futur firmware upgrade this but actualy is only 1.3 or 720p not full hdCamera only 1,3mio pixel? Different models?
Hi @jemesecurise ,
is that true? As I always read 2.0 Mio pixel camera...
Video Compression H.264
Image Sensor 1/2.8” 2MP CMOS
Focal Length 1.9mm
Angle of View H:140°
Day/Night ICR
from the webpage...or
are there different models out there?
INT
No dahua upgrade few times a year
With the return of dahua agent
For exemple vto2000a had 5 upgrades in 2 years to fixe bug or add function.
The images @Steff posted here: Looking for a good door intercom, any info on Dahuas VTO3211D-P2 and VTH1560CSNo its noticed 2mp but in relaity is 1.3 MP max, maybe futur firmware upgrade this but actualy is only 1.3 or 720p not full hd
were 1080p, a bit noisy but still 1080p.
i check by doubt but i confirm its only 720P you can see here
Thanks for double checking. Odd that 1080p is currently not supported despite the 2 MP cameraYes you are absolutely rightjemesecurise, thanks for your info!
Via web interface I can also only set these resolutions:
View attachment 27471 View attachment 27472
Even though I was able to set the resolution on my NVR to 1080P. This then must be without effect.
I was also wondering why the resolution keeps changing back after a little while to lower counts.
. Hopefully one of the next firmwares will fix this (although I do not think it is essential) as well the 'auto' adjustment 'feature'...
Well, yes indeed but maybe someone uses as a normal IP surveillance camera... To cover bits of the front yard.to be honnest, 1.3MP 720P is largest OK, in fact when someone ring is about 50cm - 1m , so you have an impressive quality, by the way the VTH1550 is 800X600 so not need more![]()
Ups... So the hardware is not that capable after all!?other thing, if you add VTO on NVR dont put more 3megabit / second rate, it will loose frame
yes is doorbell dont forget, if you want an ip caméra you have an ip caméra, if you want doorphone you have doorphone hahahahaa![]()
