TechBill
- Nov 1, 2014
- 1,829
- 1,190
verify with your seller that the NVR you want includes IVS support; if it does it should be pretty simple to hook a strobe up @ the NVR and have the camera's linecross trigger it for a few seconds.
IVS is an optional feature for most NVR's, if you dont double check before buying you might not get it.
Thank you for the head up, I will check with seller first
What are your thought on 4231 as a front door camera? Do you think the 3.8mm lens is wide and close enough to cover the front door entrance way?
I plan to put 5231 on the corner of the house pointing to the walkway of the front door when more come in stock. But only the 4231 will be my trigger point to alert us someone at the door before they ring our doorbell (We have a light flasher when door bell is pressed).
Any feedback or advice is greatly welcomed!
Thank you
Bill
