There is a "new" firmware V2.622.0000000.7.R.180404
https://www.dahuasecurity.com/products/productDetail/6681 --> Download --> Firmware
it's easy to check here, and select which one suits your using.I'm really looking at getting one of these. I just have to figure out where to mount it. If I mount it at the end of my house I have a gutter that is kind of in the way. If I mount it at the end of my house I lose sight of some of the street. Is there any place on here that shows different mounting options. I did see the mount it comes with but I may need one that mounts to a soffit or a pole that is up higher at my peak. I just want this cam but need to figure out my best option. If I sent some pictures does anyone think they would be able to help me with placement? Thanks.
PFA support.
Just tested it on some moving objects, panning motion, and it seems to work. (maybe a placebo effect)
Need to test it some more.
What does PFA give us again?
Does that mean, for example, an intruders face when on the move will also be less blurred when the camera is stationary?
What kind of screws did you use to screw into the brick?This is the camera with the junction box and corner bracket.
Again, just to make sure I understood correctly, you can install NTSC over PAL?
No, it means, that the camera keeps focusing while zooming in on an object. I think, that it also keeps focusing while moving the camera. You could see it like a continuous focus when the lens moves.
Here you can see a demo of what Predictive Focus Algorithm (PFA) does / means:
I have tested it, and have to say that it works quite well![]()
That turret is very close to falling, ring isn't latched on the back side.
You are suppose to go to the NVR's main menu and select Shutdown, before pulling the plug.
If the HD's are installed in the correct orientation. The cables should be fine.
