looney2ns
Be sure you held the reset button long enough. Some report needing to hold it up to two minutes.
Happy to help, sure you will be pleased with the 49225, it is a very capable camera especially at the current price. The biggest downside after getting one is you might find yourself reaching for the PTZ control when viewing the 5231'sThis helps a lot. Thanks you for taking the time to do/type this. For me, that alone makes it worth purchasing this camera. Its on my list of things to get, after I get my 5321s installed.
Not had much luck getting Dahua to acknowledge the problems I've had since firmware update, they seem relatively keen to deal with other requests but almost ignoring anything linked to the 49225, I hope this means they are either thinking about it or busy working on a resolution, currently I have to run a 'Lens init' at least every 24 hours and the flickering persists regardless. Radio silence does not inspire me to purchase anymore Dahua PTZ's and to some degree anymore Dahua kit full stop, hopefully they will come back to me with some good news soon.I
I have tried VBR and CBR, also dropping down to 720p without change, this is not something I have ever noticed before so 100% firmware cause, do know what you mean about light and dark changes causing a similar visual effect and maybe even some compression in the area of image with lots of activity but this pulsing is right across the image and continuous whilst also being consistent.
Understand your thoughts on firmware, sadly I might never see the old image quality experienced on previous version, lesson learned for me, should have known better really but was hoping this firmware would fix the PTZ presets in Milestone for me, sadly even that didn't work out. Avoid this version unless you have a very good reason to upgrade, rest assured I will be leaning on Dahua pretty hard in an attempt to get this sorted.
Mine came with 2.422.0000.0.R.4.2510 and for the most part that seemed pretty solid, others have reported the latest firmware in NTSC format seems OK but my experience with both NTSC and PAL has been anything but. Stick with what version is on it out the box unless there is a very good reason to do otherwise would be my advice.I have a 49225 due here tomorrow. What is the date of the recommended and reliable firmware I should be looking for?
OK, I reset to factory defaults and the flickering is actually worse now and more pronouncedwhich is annoying, also the presets for PTZ will not accept unique names and simply revert to Preset1, Preset2 and so on, they were fine before the update. All in all the PAL version of this firmware from my experience is best avoided until they resolve these problems, I will wait to see what Dahua come back to me with regarding this before taking further steps, can't face loading the NTSC firmware today, maybe tomorrow!
I also noticed a light shadow/vertical band on the left of the image with this firmware, takes up about a quarter of the image, objects in this area seem to be less in focus - surely firmware couldn't do this but it sure as heck wasn't there before. Sometimes wish I had better luck or less of an eye for detail!
This unit came from Andy mainly due to it not being available locally, did drop him an email but hadn't heard back, I know he is very busy and I feel that Dahua should take responsibility for this anyway, they all come out the same factory to my mind but this is just an outsider looking inWho did you purchase from? Sorry if you've already said and I've forgotten...Unless it's an authorized dealer for your region, I have my doubts that the company will try to help...Usually you have to deal with the seller that you purchased from.
I was having a chat with another guy a few days ago and mentioned your issue. Apparently, as I suspected, the new firmware that you're on does have a signature inspection, thus it will not natively allow you to downgrade to the older firmware....However, you can downgrade by transferring some files via TFTP...You have to know "hardware id" values in order to make this work...Fortunately, I have a way of discovering these values on mine and they would be the same values for yours since they're based on model number, rather than serial number....So if you're interested in downgrading, I would be glad to provide him with the needed info from my camera and he and I could help talk you through the TFTP downgrade process...If you think it's worth the time and effort, just let me know and I'll be happy to help.
I will give it some time and see if any new firmware appears but if nothing happens then I will most likely take up your generous offer and see what can be done with TFTP![]()
It does seem that way, I guess in this instance it probably wouldn't matter either way when the firmware is problematic. Mixed feelings about Dahua at the moment, might dip my toe in some Hikvision kit from local authorised supplier and see how that compares.They should, but unfortunately they don't see it that way. They're on a regional business model in which if you want their support and 5 year warranty, you have to pay extra and buy from someone authorized in your region...If you buy cheaper from Andy, you only get his personal 1 year warranty and support. Hikvision is the same way. Buy cheaper from China and they refuse to help you.
On the EmpireTech store on AliExpress, it's stated they give a 2 year warranty. Maybe that's only if you buy through the store.
Andy told me "1 year" through a private message a few days ago...So who knows what you actually get....Buying chinese cameras is like a box of chocolates...Never know what you're gonna get! lol
Agreed, maybe that option will come in due course. I guess in many respects we are spoilt for choice in real terms. Shall take a look at the Yunch when I get some time later.I would take Hikvision in a heartbeat if they offered a PTZ with starvis sensor and for a reasonable price. Last I checked, they didn't offer it...I've been considering the Yunch starvis PTZ. There's a certain few on the board that freak out when mentioning it, but what I've seen of it looks impressive and very few reports of failures on the speed dome versions...But I won't open that can of worms again...
Yunch 20x PTZ With Starlight Module.
Worth considering all sides of the argument there...Though me personally, I wish I would have gone with the Yunch instead of Dahua.
I was hoping that Huisun would come out with a Starlight Module in their PTZ camera. I have had good luck with the 4 I have and would love to have one with the latest Sony starlight module in it.
