wxman
Pulling my weight
you guys still think this cam is the best bang for the buck for a first PTZ?..need something to monitor unscrupulous contractors..
Probably so, although it really depends on your exact needs. If you need 1080p video, fast pan and tilt with 360 degree pan range, fairly strong amount of zoom, good low-light performance on faster shutter speeds (without motion blur) and decent wide dynamic range ability; but not concerned about color balance or slow shutter ability and no need for a wiper...Then yeah, this is probably the best bang for the buck....
If color and slow shutter is important and you can sacrifice a bit of speed, dynamic range and low light performance on the faster shutter speeds, then I'd lean toward Hikvision.....(or Huisun/Imporx speed dome if a wiper happens to be important).
If you speed isn't important, you only need about 250 degrees pan range, only need moderate zoom and lowest price is more important than long-term reliability, then the Husisun/Imporx Mini ptz would be your best bet...Just don't count on it lasting more than a couple of months based on past history with a number of members here.
