Crazykiller
Getting comfortable
I use the idle function it works as I think it should. So with this setting I have posted here, it will return home (preset 1) after 30 minutes of NO movement of the cam no matter what position I leave it in.
Do you also use triggers which are configured for IVS in the NVR?
In my case i could agree to your explanation. Same here. Only if the cam was moved to a preset by a trigger from the NVR it doesn’t go back to idle position.
