looney2ns
yes I updated PTZ as well...the 2.623 180913 .bin along with the 3.02.93 ptz
...I think I did re-import my settings...could that be the issue? should i clean out the settings with a reset?
Yeah, I'd try that.
Yeah, I'd try that.
Anybody else upgrade to the 180913 firmware and have problems with the web interface becoming unresponsive after about 6-8 hours? I started noticing the problem on the previous version from August, but not as extensive, so I updated when I saw the 180913 available and it got way worse. I finally reverted back to the April 2018 version and it's been solid since then. I did do a full factory reset after installing 180913 including wiping the network settings, it made no difference. Not sure if it's something on my network that may be causing the problem or something built in to that firmware version. I don't have an NVR or anything else communicating with the camera, so that seems unlikely to me but you never know I guess. I don't have the camera on a separate VLAN yet.
Download April firmware on Dahua Italy official site Firmwares
great! gonna give this a shotDownload April firmware on Dahua Italy official site Firmwares
It's working great although BI seems to loose PTZ control of the cam once in a while. Then I have to log into the web interface to regain control.
I finally finished the recessed install of my SD49225T PTZ. It was a lot of work but it's more discrete this way. I mounted it inside the 2nd story window frame above the garage door. The other cam is a Dahua 8MP to keep a wide angle eye on things. It's working great although BI seems to loose PTZ control of the cam once in a while. Then I have to log into the web interface to regain control.
If you have set the PTZ Profile in BI to the "Dahua New" profile, then this could be the problem.
Set it to ONVIF(OXML) and then it works fine. At least that did the trick for my 49225 in BI.
I've mailed with bi support, and he is looking to fix it![]()
Nice job, do you have a way to remove it for service?
I tried the ONVIF setting a couple of times but I don't get any PTZ response at all. "Dahua New" is the only setting that works for me (not reliably). Maybe my firmware is different than yours.
System Version 2.622.0000000.7.R.R4.2510.9A.NR, Build Date: 2018-04-04
WEB Version 3.2.1.563437
ONVIF Version 16.12(V2.4.1.513183)
PTZ Version 3.02.93.RHNZ_170518_22722
I am using that version and Onvif works fine for me. Be sure you use the find/inspect button and it should set everything for you.
