why is mark as vehicle set to person?Thanks, I have substreams off on BI so I can view in better quality. Hope the attached help.
Vapour from my boiler causes a load of CPU jump!
Is there a good current document on how to setup and tune CPAI? I am looking at this from moving to substreams, recommended size/quality of those streams, which models to use, etc. I see so much conflicting information between this forum, BI's forum, reddit and CPAI website. It would be great to build a site somewhere with "best practices" to make this all work easier so we can all spend time on other projects. I am game to document this but I dont have 200 hours to try every combination of settings and dig through all the various sources of information as some of them seem very dated at this point as well. Thanks!
They do make one that fits in that Wi-Fi chip slot. I recommend going that route. I have a USB one and I had issues with it. Some people don't but I personally didI'm using a Minipc for my Unraid BI server. If I get a USB coral device how do I configure it to work?
Or instead of USB do they make a coral that fits in the internal wifi chip slot since I'm not using it.
Link please?They do make one that fits in that Wi-Fi chip slot. I recommend going that route. I have a USB one and I had issues with it. Some people don't but I personally did
This is the WiFi tpu I used in my lenovo thinkcenter. Works faster than the USB.Link please?
Thanks, I have the SER5 miniThis is the WiFi tpu I used in my lenovo thinkcenter. Works faster than the USB.
I've also just ordered a m2 WiFi format tpu and m2 b+m tpu format to have a selection.
I have an a+e format that I bought by error.
Need a pcie adapter for that which I haven't bought yet.
May see if I can sell that one. Bit of an odd format unfortunately
Also if you've got a sff/tff you don't want usb devices flopping about. Just makes it tidier
Thanks, I have the SER5 mini. So WiFi adapter probably only option for me. Does the Coral AI do anything for photo or video editing? Or just for codeproject?This is the WiFi tpu I used in my lenovo thinkcenter. Works faster than the USB.
True. I had trouble with the usb on my small lenovo as it would sometimes change usb device number so had to update the proxmox lxc config.It’s purpose built for AI, and won’t do more general calculations like a GPU would. I’d also recommend the one that fits in your WiFi slot. The USB ones tend to be trouble.
I too was impressed with them. Ended up ordering a few of each they had. I currently run a few with the pci express adapter and another with a raspberry pi5 with the ai hat. The pi5 is flawless and rock solid.True. I had trouble with the usb on my small lenovo as it would sometimes change usb device number so had to update the proxmox lxc config.
But now it's been on my unraid server solid for 1 year.
But yeah I've been testing the WiFi tpu and very impressed with it so ordered more. One for the unraid and another m2 for a 2nd pc.
ordered the wrong one, got the mini pc apart and the wifi slot says M.2 Wifi 2230Than
Hey guys,
I haven't really checked these forums in over a year or so. I've got a spare USB Coral adapter from another project and I see now that CPAI now supports Coral TPUs.
At the moment, my BI server is using a GPU which is connected to another PC running CPAI in a docker container.
So I've installed CPAI on the BI machine and also installed the Coral USB drivers.
When I go into the CPAI Explorer and run some benchmarks, I am extremely underwhelmed. I'm getting 0.5 operations per second when using the same test image as the remote CPAI server with a 1050ti getting 8.8 operations per second.
I was prepared to take some performance hit, knowing that this is just a USB TPU, but I wasn't expecting it to be THIS bad.
Is this level of performance expected? Or am I forgetting to do something?
Lot's of posts here of people experiencing poor performance from Coral even in a M2 slot, so a USB will be even worse. Coral just isn't ready for prime-time yet.
Send me the test image and ill use it on my and tell you the results. I got the the pci cards one runningAh, I see. I'll check back in another year or so.
I guess I'll rely on my remote GPU server solution until then.
| # | Label | Confidence |
| 0 | bird | 64% |
| 1 | bird | 61% |
| 2 | bird | 57% |
| 3 | bird | 55% |
| 4 | person | 54% |
| 5 | bird | 54% |
| 6 | person | 54% |
| 7 | bird | 54% |
| 8 | person | 52% |
| 9 | bird | 51% |
| 10 | bird | 51% |
| 11 | bird | 51% |
| 12 | person | 50% |
| Processed by | ObjectDetectionCoral |
| Processed on | localhost |
| Analysis round trip | 745 ms |
| Processing | 189 ms |
| Inference | 9 ms |
| Timestamp (UTC) | Tue, 02 Apr 2024 03:14:39 GMT |
