Can you send Blue Iris support this request, I asked him the same.
Just emailed them now. Looking at today's results I'd have an almost 100% success rate had it picked the best "plate"
That's the exact problem I am having. Go look here, open the install log and see if the installation of the ALPR timed out. I am currently just trying to get it to work in the explorer.Mike, I need your help please. I have been installing and un installing codeproject many times and upgrading and downgrating blueiris , for some reason I can not get it to work. I get 100% of ai timeout and or not responding. It show that I have a GPU, no high CPU. Currently, installed codeproject 2.4, 2.6 2.7. At one point, I was able to get the custom like delivery and everything else including the plate. Interesting enough , if I run the jpg in codeproject it shows the dayplate but not the plate number (could it be because is electric?) anyway so I can test it tonight, any suggestion on a release of both codeproject and blueiris that I'm sure I get something from ai? Any suggestions would be greatly appreciated. Thanks.
Sent from my SM-S906U using Tapatalk
I'm not on the machine right now but I do see an error on the alpr. Hopefully we will find a solution. I had it so close to be perfectThat's the exact problem I am having. Go look here, open the install log and see if the installation of the ALPR timed out. I am currently just trying to get it to work in the explorer.
Exactly - I still have mine on Port 5000 and all is good - unless I am missing something special that port 32whatever offers - highly unlikelyI can change the port to whatever I want. It's actively running on it.
Were you able to get yours working? I have been over on the CodeProject group and tried everything they said. I finally have given up on this one. I may try again once they put out a new version or two unless you have any suggestions.I'm not on the machine right now but I do see an error on the alpr. Hopefully we will find a solution. I had it so close to be perfect
I was going to reply just now. I decided to go with the latest working bu and codeproject 1.6.4, it works great. The only minor issue if you do that is that you may get error 404, remove the custom pt and you should be fine, I was concern that was related to my computer. I will wait until things get ironed out with codeproject before I install the latest. Please keep me posted as well if you make any progress.Were you able to get yours working? I have been over on the CodeProject group and tried everything they said. I finally have given up on this one. I may try again once they put out a new version or two unless you have any suggestions.
Maybe a dumb question, but where can I find 1.6.4?I was going to reply just now. I decided to go with the latest working bu and codeproject 1.6.4, it works great. The only minor issue if you do that is that you may get error 404, remove the custom pt and you should be fine, I was concern that was related to my computer. I will wait until things get ironed out with codeproject before I install the latest. Please keep me posted as well if you make any progress.
I had another machine with a fresh installation of Windows and it still did not work well. I will wait.I know many of you having problems installing CPAI probably won't like this solution BUT, given the time many of you have installed and uninstall time after time with no luck, I recommend a fresh install of the OS and I would almost guarantee it will go on perfect then. If it doesn't you more than likely have hardware issues. Then once you get your Windows configured and BI installed, make an image as well.
Great question, I happen to have it downloaded in my drive. I think I took it from codeproject web site.Maybe a dumb question, but where can I find 1.6.4?
Yeah, it has the files but not the installer. If you try to follow the instructions on their website, things have changed so it doesn’t do anything.Great question, I happen to have it downloaded in my drive. I think I took it from codeproject web site.
If I could somehow come up with an installer for 1.6 or 1.64 I would try it just to confirm it works on my system that I have had so many issues with the newer versions on.Yall have definitely scared me away from moving on from 1.6 after reading through all these nightmares!
Not sure if I can attach that file but I will try it tonight , I may need to rename it txt to go thru the forum. I have added it to my calendar so I don't forget. FYI, EST time here, expect it around 6 pm.If I could somehow come up with an installer for 1.6 or 1.64 I would try it just to confirm it works on my system that I have had so many issues with the newer versions on.
That would be awesome. Not sur e if it would go through email but we could try that too. I will look for it later. Heading to have a beer with my retirement buddies.Not sure if I can attach that file but I will try it tonight , I may need to rename it txt to go thru the forum. I have added it to my calendar so I don't forget. FYI, EST time here, expect it around 6 pm.
