Can anyone tell what model is used in this video:
Is it based on YOLO or something else?
Does it require a different type of IP camera?
The current version is 2.3.4, version 2.4.x should be released shortly, I am currently prerelease testing.What is the latest version supported in BI?
I will try to put something together this weekend@MikeLud1 Any tutorial on how to use the training feature in v2.3.4?
I asked this question on CP.AI forums and did not get any replies.
Are you saying the BI will use 2.3.4? I'm on 2.0.6 right now as one of the older BI version had not supported the latest cp-ai at the time; nothing was being detected. I'm not using the license plate option.The current version is 2.3.4, version 2.4.x should be released shortly, I am currently prerelease testing.
BI has been working fine for me on v2.3.4. Version 2.4.x should be released soon. So wait to upgrade until v2.4.x comes out. When upgrading you will need to do a full uninstall before upgrading.Are you saying the BI will use 2.3.4? I'm on 2.0.6 right now as one of the older BI version had not supported the latest cp-ai at the time; nothing was being detected. I'm not using the license plate option.
Same for me did you ever figure out what it was?Testing and tuning -> Analyze with AI doesn't appear to be working for me. Actual clips are getting analyzed. Is it just me?
Sorry to jump in here & may have been mentioned but this seems a very knowledgable thread.
Wanting to speed up the AI process.
I use motion detection then AI (now CPAI, just changed from deepstack) to make sure a vehicle ,
then I use python code to do the LPR (plate recogniser SDK) then send telegram to advise X is at the gate & if known it opens the gate. What I would like is for the gate to open almost immediately however currently can take from 4 to 10 seconds, not that much of a big deal really but seems unnecessarily slow
My code is fast, less than 1 seconds, it just the AI I think is slower than I would like. 2nd hand i7 4760 16gb, I thought pretty fast albeit rather old. Handles motion & 7 cameras great. Seems from motion detection to the alert is 4-10 seconds
Have ordered a RX6400 so hoping this will give quite a boost, always go Nvidia normally but limited choice, slim case & low power, OEM HP PC.
What I am trying to work out is does the AI analyse every image even if the first one it finds is a car, I can see all the ms data for following images so guess it does but strangely does not seem to take that long, I would think much more than 10 seconds if that was the case.
I understand if you want a cancel option it would have to check all images before alerting but if nothing in "cancel" can it or does it alert immediately.
I want it to potentially detect a car early on to be fast but if poor light etc. so I need 20'ish+ real time images to give it a chance to be sure of a car as it gets closer. Slow detection is fine in this situation but 90% of time catches "car" very early on & good to make use of that.
sorry bit rambling in the end.
The new version should be released any day now, there where some bugs. The version I am testing is 2.4.3Release Notes - CodeProject.AI Server v2.7.0
A Guide to using and developing with CodeProject.AI Serverwww.codeproject.com
there are release notes for 2.4.1 but I cant find a download link for that version.
Is there a "Latest Critical or Highly Stable Update" like Blue Iris does?The new version should be released any day now, there where some bugs. The version I am testing is 2.4.3
