harleyl7
Pulling my weight
- Jun 4, 2021
- 265
- 225
thanks, Ill give it a shot. @MikeLud1 are those settings linked above still up to date? we can carry the conversation on over to the correct thread.@harleyl7 There is a separate thread dedicated to ALPR.
My current settings are based on Mike's most recent suggested configs listed here: Blue Iris and CodeProject.AI ALPR
And if you haven't done so, use CodeProject.AI Explorer UI to test license plate reading by uploading an image from your camera.
Did you make the changes that are in the below post0 9/12/2023 2:57:42.186 PM Cam1 AI: [license-plate] DayPlate:60% [309,31 355,60] 137ms
0 9/12/2023 2:57:42.189 PM Cam1 AI: DayPlate:60%
Do I need to install something to get it to read the plate?
Yes, I did. I might try uninstalling the module and reinstalling since I installed CUDA after the module.Did you make the changes that are in the below post
CodeProject.AI Version 2.0
Yes and Yes, make sure you have CUDA install first before adding ALPR module Okay last question haha where do I get those?ipcamtalk.com
Do you see any errors in CodeProject.AI log, if post the log.
log looks normal, try testing with the attached image.View attachment 172193
just no plates found and ive tried multiple images
The OCR module is not need it is built into the ALPR module.the restart didnt work either. still getting no prediction returned. Do I need an OCR module or is it built into the ALPR module?
I have seen this before not sure what is causing it. can you open a command prompt and run nvcc --version then post a screenshot of the resultslol so installing OCR let it return predictions, but its not working -
here ya go:I have seen this before not sure what is causing it. can you open a command prompt and run nvcc --version then post a screenshot of the results
This looks normal.here ya go: View attachment 172202
Yepp I have that thereThis looks normal.
Did you download and run cuDNN install script to install cuDNN 8.9.4.
After running the bat file you should see the below folders
Everything so far looks setup correctly maybe the 3GB 1060 does not have enough memory, to verify if it is a memory issue try your 1080Yepp I have that there
Should I give it the ole restart from scratch. Fully delete CPAI and try again?
