catcamstar
- Jan 28, 2018
- 1,656
- 1,196
So, latest....
What am I not doing?
You are not posting the configuration of your VPN server & client
How are those configured? "Allow access to LAN"? Are you successfully connecting? etc etc.
So, latest....
A static address solves part of the problem, you will no longer need a send service.
But you still need to address security and encryption.
To access your system you will need to open a port on the router. This is not a very good idea.
I may have asked his before, can your modem/ router be put in pass through mode, so it no longer acts as a router, it uonly acts as a modem. You will need to ask your internet provider, or people that use your internet provider.
How much is your provider charging for the static IP.
Hi guys, you are all correct.
I rushed out and got a VPN but it was a client setup and not a server.... my bad!!!
I have spoken to the VPN provider, and they have said that they can offer me a dedicated IP address which I would then use to access my home network.
I think this seems the easiest option!!!!
It's definitely a steep learning curve!!!!
