have you emailed support? have you tried the solution above?i have the same problem now a bluiris bug ..........
c:\windows\system32\msg.exe * /TIME:5 "msg.exe test message; closes in 5 seconds."
Maybe if there is a way to make the program reopen if closed
Can't seem to do that with the task scheduler workaround suggested. (the task gets executed on a schedule and i also need to put in the parameters for the relay module).
