SpacemanSpiff
One tool none of you listed was a cable stretcher?!?![]()
And don't forget packet wax... a topically applied cable speed enhancer
And don't forget packet wax... a topically applied cable speed enhancer![]()
And there's a limited amount of work you can do to a board that is multi-layer and/or uses SMT. Just some discrete components like diodes, caps, resistors, chokes, transistors, etc. but it's OK....she won't be holding on to that iron long anyway.That photo seems only a wee bit less cringy worthy than this one. For those not familiar with soldering... she is holding the soldering iron by a component of the iron that reaches quite a high temperature. The brown band is were this iron should be held, so as not to incur 3rd degree burns
I think the village people like to pull something other than wires.
Good luck!sorry guys. All of my free time is being diverted to work. Suppose to have 3 techs, but I am the only one. Boss wants to retire and sell me the company. To do such, need home equity loan. To do that, VA appraisal. So now I must rush to fix my ongoing DIY projects (I have 15 square holes in my walls & ceiling to at least plug up and other various stuff).
I will return to these 'how-to-wire-home' guides when things settle down a bit as it may help encourage folks to do hard wiring on their own for IP cameras or audio or alarm or etc.
Another great thing a non-professional home environment, are those garden stools, foam flooring square sheets, yoga mats, etc. Your knees will thank you. At work, the youngins are ok to set on their knees. But not me at 52. I prefer sitting on my 5 gallon bucket of string.I may have missed it, but did anyone include knee pads?
I feel your pain. I had a similar incident quite a while ago that turned out to be my $7 tester so I float-tested it in a nearby lake and it failed. I still use a $7 tester to this day because frankly, I don't think I've had more than 5 or 6 bad out of a 100 crimps ( I didn't start out that way) and I prefer to drop a $7 tester from 10 to 20 feet onto a cement driveway. My Fluke stays on the ground.So in the couple of hours between testing before and after burial, the crappy cable tester failed so that it always shows 5/6 bad now. Threw it in the trash.
				I just read this.Thanks everybody.
I pulled cable for a year and 1/2.
I used everything Holbs listed. plus electrical tape.
I wonder if there is a photo showing how we attach pull string to a run of Cat cable, and a decent tape job.
@Mike A. I came up with a 1"PVC Javelin (lol) for working by myself on a Man lift at Target stores pulling in an extra line over the retail floor to the pharmacies.
But yeah not a home owner problem.
fish sticks dont travel very far on a toss. But the PVC had some weight and I could make it across 5 or so Ceiling tiles ( with cat5 taped to it.)
this punch tool is the love of my life@Holbs
We are taking up a collection to get you a new punchdown. You wore right thru the rubber handle!
I think we might need to setup a gofundme or a GoFlukeme....![]()
