I'm not sure if the undocumented API I'm using to pull the video for export supports speed modification, but I've made a note to try. Any ideas on where/how the playback speed should be set for the export? I could just use whatever your current playback speed setting says, but that might confuse more people than not. And tweaked playback rate also disables audio.
Yes, that would be ideal - a check box to enable, and an input field to specify the multiplier - much like the BI console currently does. This way, the user can specify any level of compression. With BI, I've gone as high as 200x and the results have always been butter-smooth (vs. the choppy playback experienced when playing back at 16x or higher via the client player (IE, UI1-3). Audio integration is currently forfeited when exporting time lapse in the console as well. Small price to pay to compress a day-long clip to a few minutes.
After adding my 30th camera, my CPU has been redlining more than in should. I've done all tricks to reduce load, but ultimately what got me back to a manageable level was to make a few of the cameras direct-to-disc. By setting 5 cameras to D2D, my CPU dropped back below 50%. I wish I could leave it on, but rendering each frame on the fly while recording is apparently very hard on the CPU.
In any case, if there is a noteworthy event, when I use the console, I can tick the option to include the overlay, and it renders off as though I had never written to D2D. Just thought it'd be neat to do that from something other than the BI console - especially if it was a simple matter to incorporate.
A few people have asked for that. I keep telling them to make their camera embed its timestamp. LOL. But I've just now made a note to implement this. Upper-right corner of the clip player work for you?
I'd settle for anywhere, to be frank. Where ever you think it fits best and is the least amount of effort for you
