I will be releasing an update to Blue Iris Tools soon and address some bug fixes as well as some new features such as 'detect freeze screen' and Pushover integration for instant push alerts to your cell phone. Stay tuned
@dammad, not sure why that is, should have no issues at all on an i5. What version of windows?
Hi, I have been having an issue the last few days re FTP uploads of Images to WU - see here in the BI Troubleshooting section. I have reverted to BI Tools 1.01 and all is well again. Bug maybe?
Regards,
Ian
Just using BIT to overlay - if i use the old version all is OK, BI can FTP, if I use the latest version for some reason FTP stops...weird.What are you using BIT for? As of right now BIT only supports text overlay weather, not images.
That's very weird, BIT shouldn't interfere with that at all. Were you using the webserver Watchdog on the new version when you tried? If so, what port is your BI server running on? Thanks.
Hi Mike. Yes I was/am using Watchdog on 8181. When I have a little more time next week I will re-install the latest BIT version and see if a different port makes a difference.
Regards, Ian
