I have BIT v1.5.0 ready to go, which works with BI5...Anyone want to test it before I officially release the update? If you upgraded from BI4 to BI5 then BIT should detect that and automatically adjust BIT's settings.
Thanks!
@Mike I installed and registered BI5 on a Win 7 Home 64bit that had BI4 but I removed BI4 first via the Control Panel.
BI5 running great, no issues, errors, etc. upon install or run.
However, attempting to install BIT v1.5.0 yielded the following error:
EDIT: BIT v1.3.2 did the same.
