Oh you have made a mess of things NOW lol.
You may want to deregister BI and move it to the C drive.
Yikes... Thought I might have to do a total reinstall a long time ago.Oh you have made a mess of things NOW lol.
So, deactivate from the BI settings, delete everything on E and C drive that has to do with BI? Then reload BI from my downloads and install on my C drive.Oh you have made a mess of things NOW lol.
Is there a way to save my 10 camera settings before I do this?Yes, but make sure you have your BI activation key for when you reinstall on the c drive.
Since the E drive should just be for video - I would delete everything.
But first decide if you will rebuild BI from scratch or do an export of the settings and import them in on the C drive.
So, I saved the export to a folder on my desktop cause it wanted to save to BI, on the C drive, which I will be deleting. Is that right to do? Again, not real computer savvy.Go to the main BI settings page and do an export of the settings. Just to be safe, I would also go into each camera and export out those settings as well.
In theory, the global export should have them all, but I have seen instances where a camera was missing.
Going to redo my BI after a trip since it is working. However, your tips for getting my clips and archive seem to be going very well except for one thing. Don't think I'm saving ALERTS to be able to look back on. Was hoping to be able to store at least three weeks' worth, you stated before that it takes quite a bit to make up 1gb.Oh you have made a mess of things NOW lol.
Is that under Trigger, When triggered, Add to alerts list, then pick Hi-rez JPEG files?Glad to hear!
The alerts folder will be empty (unless you are telling it to save Hi-rez or burn Deepstack on the image) as the alerts are the thumbnails on the main console to the left that corresponds to each triggered event.
So if you want the photos, then tell it to save hi-rez snapshots.
