Also, I notice all these residual .bvr files from years back still sitting in my folder that are 1KB in size. Not sure what those are and how they are being saved and not getting purged. Is it from "Include JPEGs on ALL CLIPS" setting?
Are those files possibly protected video files, that you marked to keep!Also, I notice all these residual .bvr files from years back still sitting in my folder that are 1KB in size. Not sure what those are and how they are being saved and not getting purged. Is it from "Include JPEGs on ALL CLIPS" setting?
No, I've never used the protect feature.Are those files possibly protected video files, that you marked to keep!
The files may still be "protected" if they have the read-only attribute set. See items #1,2 in my post above.No, I've never used the protect feature.
Good to know!First, apologies to the OP....didn't mean to highjack the thread.
I manually ran the "REPAIR DB" utility and all those old 1KB bvr files went away. Not sure why that is as I have it scheduled to run every Sunday and would have thought the weekly run would have taken care of them.
The higher up of a number I make it, the more it says its overallocated.WHat happens if you change the 1000 GB to something else? like 9000.
Is the 16TB partitioned into different sections?
View attachment 213964View attachment 213965
Not sure I fully grasped #10. Do you have some screenshot demonstrating how you have subfolders set up for each cam? BI settings screenshots and may screenshot of the folders?
Good Morning Did you ever find a solution ? I seem to be having this issue now as I have 3 drives for 35 Tb. Is the drive with all of the storage the issue or is it something else ? I cut my first drive to minimal sending everything to drive 2 then when it gets to about 80% over to drive 3 to delete. Note: I just installed drive three as this just popped up out of nowhere 2 weeks ago .,, Since then I upgraded the memory and added the said drive .. I DID have over allocated drives but resolved that in storage . We also have approx. 250,000 records ( What BI states booting up bottom left in the maint. window ( Greater than 250000 records) . Seems like every 4 days it stops with that crash error on the appNot sure I fully grasped #10. Do you have some screenshot demonstrating how you have subfolders set up for each cam? BI settings screenshots and may screenshot of the folders?
version .27 is buggy with several issues. I would roll back to .25 which is the latest Stable ver.Good Morning Did you ever find a solution ? I seem to be having this issue now as I have 3 drives for 35 Tb. Is the drive with all of the storage the issue or is it something else ? I cut my first drive to minimal sending everything to drive 2 then when it gets to about 80% over to drive 3 to delete. Note: I just installed drive three as this just popped up out of nowhere 2 weeks ago .,, Since then I upgraded the memory and added the said drive .. I DID have over allocated drives but resolved that in storage . We also have approx. 250,000 records ( What BI states booting up bottom left in the maint. window ( Greater than 250000 records) . Seems like every 4 days it stops with that crash error on the app
From Windows 11 pro latest upgrades to windows and BI software : Event viewer but the BI logs have nothing in them ( on the desktop - White popup stating BI Has crashed and the program freezes )
Faulting application name: BlueIris.exe, version: 5.9.9.27, time stamp: 0x67b4be19
Faulting module name: BlueIris.exe, version: 5.9.9.27, time stamp: 0x67b4be19
Exception code: 0xc0000005
Fault offset: 0x000000000117f193
Faulting process id: 0x3484
Faulting application start time: 0x1DB8B7964806314
Faulting application path: C:\Program Files\Blue Iris 5\BlueIris.exe
Faulting module path: C:\Program Files\Blue Iris 5\BlueIris.exe
Report Id: 617c3ae9-5df6-4751-8061-19086fba06db
Faulting package full name:
Faulting package-relative application ID:
Yea, Thx for the reply as I'm running into this now as think the clips.dat file may be the culprit/issue as its quite large! As for storage I had to increase to 3 20 Tb drives as its getting bad and only 13 cameras .. Lots of outdoor activity .. I'll be back out there today to check my Storage settings today again ..The chatter on the Forum is that too many records will crash the database.
I learned that the hard way.
People make mistakes with the settings for allocating drive space with BI.
4-6 weeks of video is plenty of saved data.
View attachment 216302View attachment 216303View attachment 216305
