Blue Iris 6 built in Ai high msec vs Capi
donvito
Sep 7, 2023
17
7
las vegas
I’ve been running Blue Iris with CodeProject.AI for a few years, and it worked very well, so I decided to try the built-in AI instead.
I’m noticing some unusual millisecond (ms) values in the Blue Iris status log and I’m not sure what they indicate.
Right now, the AI is only set to detect dogs, cats, and people.
I’ve already done a fresh install of both Windows and Blue Iris, but I’m still seeing the same behavior.
Does anyone have any ideas what might be causing this?
Pc Spec
intel 13700
64gb ram
ssd os
gtx 3050
Screenshot 2026-06-20 142507.jpgScreenshot ai setting.jpgScreenshot 2.jpgcamera ai setting.jpgtask.jpg
I am not sure what exactly you mean by this statement, are you referring to the amount of time perhaps, could you clarify
I also see that you have the "max analyzers" set to 32 I would suggest that it be set to perhaps 15 and see if this improves your configuration
Have you tried editing the coco.names file to comment out the objects that you don't want the AI to detect, so that it does not try to detect squirrels etc. inside your house! Unless you are trying to detect them outside?
Yes in the blue iris status log all the trigger Ai object have 5k-18kms. before with capi i would get 20-300ms.
I also edited the coco.names and only added people cats dogs and birds.
Does anyone know if this is a bug?
No matter what i do i it shows this all the time.
You have the "Use plate recognizer for ALPR" turned on are you trying to detect license plates? You also have Pre-load models set to "All" if you are not using plates or faces you should change it to "Primary" Throwing the kitchen sink at it will only slow things down!
