I've been do looping Step 0. It it time to step out of the loop?
All in all... my installation went flawlessly. Granted, I do not have an extensive Blue Iris setup configuration either.
Also, have not yet removed anything from the BI4 related.
The issue with "Sync Profiles" is solved?
Not that I can see. Just tried to import my cameras and they are all still sync'd to profile 1 and none of the other profile settings gets imported. This was with version 5.0.2.5. Does anyone know of a fix?
Set them backup from scratch.
I came here to see if I could not have the extended be a 'subscription' where it charges me again in a year... what I found was I should not upgrade if I want it working and don't have time to mess with it... I will just buy a new install and install on a fresh windows install... if you are going to charge annually, the software should not hose itself when you uninstall the previous version..
you are misguided. The software does not "hose itself" when uninstalling 4...there is a bug. If you believe its intentional then you should really look at another vms. There are plenty. You are NOT required to have an annual subscription, you can either purchase a one time upgrade for 35 as clearly explained on the blue iris website or buy the annual subscription and then cancel. Dont be lazy - go to the blue iris website - its right there in black and white, and also mentioned repeatedly in this thread and others discussing upgrades.I came here to see if I could not have the extended be a 'subscription' where it charges me again in a year... what I found was I should not upgrade if I want it working and don't have time to mess with it... I will just buy a new install and install on a fresh windows install... if you are going to charge annually, the software should not hose itself when you uninstall the previous version..
Yes, we are all lying to you. Keep questioning the existence of this magical option or scroll to the bottom of the blue iris website your choice.I am questioning the existence of the $35 offer, can you share a screenshot or a link? I was unable to find it before posting, I was not lazy, and I am still unable to find it...
