shelestoff
Im sorry for stupid question, but who have issue with clicking relay, did you make factory default after upgrade? If not, just do it!
 i upload it already, Dahua specs tells that firmware is testedThe Aug firmware i will release on it soon when we get feedback from the volunteers![]()
Dahua engineers sometimes sucked, can't trust them too much.i upload it already, Dahua specs tells that firmware is tested
Dahua engineers sometimes sucked, can't trust them too much.![]()
MakeItRain- Did you still have the clicking from the relay after upgrading to the latest 4.0-1 firmware? I have the same NVR and the same relay cycling issue on 4.0
@MakeItRain
By any chance, did you see the incoming bandwidth issue, on the OSD (camera section) ?
Which isn't always true.i upload it already, Dahua specs tells that firmware is tested
Mine shows Residue Bandwidth / Total Bandwidth as 89 Mbps / 168 Mbps on a NVR5416-16P-4KS2. 9 cameras running.
i have, but anything have to be clearly confirmed.@shelestoff
By any chance, do you have direct access to dahua engineers ? In case, can you tell 'em about the SmartIR issue/bad functioning on the IP cam ? I believe that @EMPIRETECANDY already reported the problem, but maybe, with more pressure ......
Fine SmartIR
Review: Dahua HFW5442T-ASE 4MP Starlight+
For bad SmartIR, on IPC version, every video with a person at 2/3 mt in front of the camera, can show the issue.
