All my settings are done through NVRYes, because you should always reset the cam to factory defaults after the update.
Do you loose all your settings for IVS or others when you upgrade to this firmware?
Sorry did not mean to quote previous
Right now this model has a latest new firmware released last week, will post it here soon after testing. Has big new function adding.
UPDATE from 2020
DH_NVR5XXX-4KS2_MultiLang_V4.001.0000000.0.R.200221
What I always do for my own gear and managed ones:
- disconnect all POE cams
- factory reset NVR
- reboot (!)
- load firmware through web service
- factory reset NVR
- reboot (!)
- ONE BY ONE connect each cam (check if feed comes back, check if IVS is still enabled). If cam 1 is OK, connect cam 2. Otherwise debug until you have the feed.
It might be that your cams are on a too low level too. So check these firmware versions too, they might have an outstanding firmware version too.
Hope this helps!
CC
Main reason I want to upgrade is for e mail notifications.
This fixes the previous problem correct?
1 Yes, on the factory reset.I just set up mt NVR that I purchased nearly a year ago and just got around to installing. I upgraded to v4001. after initializing, setting password, static IP and connecting to my ASUS router before adding cameras. I assume it is still recommended to do a factory reset?
After a factory reset on the NVR, mine is a NVR5216-16P-4KS2E, I will need to reinitialize, set password, date, IP, etc. as if it was a new system I assume?
I only have two cameras installed so far and am upgrading their firmware as well. Any reboot, default process recommended after updating cameras?
Thanks.
Did you set the IVS rule on the NVR or in the camera? I normally set mine on the cameras.Actually, on IVS events, I get emails with attached, I've had to deleted and recreate the IVS rule.
2 yes
3 Factory reset.
Best is to set all of them back up from scratch and not import saved settings.
