HotRodDiesels
I'm missing something...
I used sadp to change the ip to 192.168.188.XX just like my other cams but with the cam hooked to my router the browser can't find the login screen even though sadp see's it.
I switched it to 192.168.1.99 using sadp and had no problem using the browser to login.
Since that worked I used 192.168.1.99 in the nvr & was able to make it work from the NVR through my router with external power supply but when I hooked it direct to the NVR nothing.
In the NVR is used 192.168.1.99, onvif, the cam is 192.168.1.99, 255.255.255.0, 192.168.1.1.
What am I missing? I bet its something simple...
Never mind, I got it, I must have had 1 piece of the puzzle wrong when I had it set to 192.168.188.xx for the NVR
