Does all functionality work after the update?The C-R-K9B2-00 hardware on the ANNKE NVR matches the firmware referenced in the Hikvision link.
sent me a private message with the serial number of the standby model, I will tell you what the latest firmware is and give you a link/I can't do the update. I get an Upgrade Failed. Device model mismatches. This is what is so frustrating. I buy ten units over the past year and eight are "outdated". The firmware exists. They are just blocking it.
ps the correct firmware should not look like this NVR_K21B2_BL_ML_STDV4.74.000_230213.zip but something like this NVR_K21B2_BL_MLNEU_V4.74.000_230213.zip
neu firmware is for OEM manufacturers like Annke and others
N48PAW0820230110CCRRL161xxxxxx
WCVU
latest firmware for NVR_N48PAW_C-R-K9B2-00 V4.71.111 build 231226What I need is the "NEU" firmware for the K9B2 version, not the K21B2. The "STD" version exists on Hikvision's website.
NVR_K9B2_BL_ML_NEU_V4.74.xxxx
NVR_K9B2_BL_ML_NEU_V4.75.xxxx
it.annke.com
the cameras are good, there are no problems with them, maybe you can’t configure them correctly, Hikvision firmware is not 100% suitable for annke cameras, or you will lose resolution or filter people and cars
this information. show events in the application, and nvr can work with this. If you don't know how to set up equipment, it's your problem, not the camera's.I haven't found any software that can inform me on the People and cars warning. Nor Home Assistant or Frigate, there is any one that catch these informations?
There is no newer version yet, this is the latest one@PHILka.RU
Do you have firmware for Annke C800 model I91BM/I91BL version 5.7.1 build 230609 or newer?
