As far as I can tell, for the camera settings in post #38, you are not saving hi-res or AI makeup JPGs, alert MP4s, or DAT files to the Alerts folder.
								I've never seen this before.this is what it does alerts and then it deletes itself so odd
0    2/17/2025 4:15:24.902 AM    Alerts    Delete: over quota 3.00/3.00GB, 722.2GB free
0    2/17/2025 4:15:25.161 AM    Clips    DeleteFile OK: D:\BlueIris\Alerts\DW1.20250130_170000.190626.5-0.jpg
0    2/17/2025 4:15:25.225 AM    Clips    DeleteFile OK: D:\BlueIris\Alerts\DW1.20250130_170000.251082.5-0.jpg
0    2/17/2025 4:15:25.228 AM    Alerts    Delete: 2 items 2.19MB 395 locked
0    2/17/2025 4:20:25.443 AM    Alerts    Delete: nothing to do [2.99/3.00GB, 721.0GB free]
	I'm confused. So the screenshot in post #33 is not the current configuration for the Alerts folder?
That post shows a size of 0 GB, and deletes the alert files once they exceed 0 GB.
Agreed.That is why I posted that - his shows 0 and I think he should have a nominal 1GB.
temp_{camname}.jpg) to the folder, so that they can be used by actions in the 'On alerts' action set that use the &ALERT_PATH macro (more here). This alone would seem to require a minimum allocation.That is the current one. That may be the issue. Originally I never set up the storage properly. I want to keep all alerts and then delete them after like a month.I'm confused. So the screenshot in post #33 is not the current configuration for the Alerts folder?
Does the log show any error or clips-related messages that might provide clues?
For example...
Code:0 2/17/2025 4:15:24.902 AM Alerts Delete: over quota 3.00/3.00GB, 722.2GB free 0 2/17/2025 4:15:25.161 AM Clips DeleteFile OK: D:\BlueIris\Alerts\DW1.20250130_170000.190626.5-0.jpg 0 2/17/2025 4:15:25.225 AM Clips DeleteFile OK: D:\BlueIris\Alerts\DW1.20250130_170000.251082.5-0.jpg 0 2/17/2025 4:15:25.228 AM Alerts Delete: 2 items 2.19MB 395 locked 0 2/17/2025 4:20:25.443 AM Alerts Delete: nothing to do [2.99/3.00GB, 721.0GB free]
Yep!!They should start showing now!
I hate to sound like arrogant but can you show me how to achieve this?The alerts at 1GB is fine since you are not saving any of the hi rez or AI type files.
Since you have two large drives, I would spread your cameras over the E and F drives.
But be strategic.
Let's say for simplistic purposes you have 8 cameras - 2 on each side of the house.
Many will put the front and back on one drive and the sides of the house on the other.
But what happens when a drive fails - you lose all the video from that portion of the house.
So instead split them - put 1 from each side on one drive and the other camera from each side on the other drive.
That way when a HDD fails, you at least have some coverage from each side.
My point is that the alerts happen but now are now no longer being recorded or showing on the timeline and I have not changed anything on the settings for this to stop working.
Both your Stored and Alerts are set to 0GB with the next action being delete.
On the Storage Tab under "New" make the next action tomove to "Stored". Under "stored" change the size to something more than 0GB. Under "alerts" change it to something more than 0GB.
