ruppmeister
- Apr 15, 2015
- 668
- 98
is there someone that maybe can try to get this camera in his blueiris system working ?
this is my cam, opened every port to the camera (DMZ)
Tried everything but can't get any working result, even tried different Blueiris versions.
Even with vlc i can't get a working stream on both computer :S
it should be rtsp://julianahof.duckdns.org:80/0
this is the ip : julianahof.duckdns.org
username: cam
password: cam
Hope someone can get it working and knows what i am doing wrong, haven't got much trouble with other cams to get them to work.
I tried real quick to add to my BI and it didn't have signal, but did pick up the camera using the inspect feature. Not sure, but try like Klasipca said and change port. Also check that you are not running it with h265 since BI doesn't take that compression feed.
