Q™
Also, look it here. Dahua with the same sensor? Getting some more info and quote.
http://www.alibaba.com/product-deta...0273984008.html?spm=a2700.7724838.30.1.Y3ZXAe
Firstly, it arrived like so:
My contribution for different modes (I kind of like no IR option and just rely on motion flood light, it looks like it will take care of the motion blur):
B&W no IR, no flood light
B&W no IR with flood light
Color no IR with flood light
Color no IR with flood light, wdr to the max
Flood light & IR on
<more sarcasm> oh wow, that IR really helps. I couldn't even see your car before you turned the IR lights on!
Sorry, won't interrupt this discussion with my lame sense of humor anymore.....at least not today!![]()
OK, some night shots. I ended up with only 2 comparisons, because I reckon it pretty much says it all...
Can you actually post what it looks like with built in IR? Also, try another shot with no IR and turn on that flood light for both cams.
Also post some daylight pictures.
Oh and Happy New Year!
I'd like fries and a milkshake added to klasipca's order, please and thanks!![]()
Milkshake and fries is bad for you, he will have water and green beans instead.I'd like fries and a milkshake added to klasipca's order, please and thanks!![]()
Milkshake and fries is bad for you, he will have water and green beans instead.![]()
The camera is great, but it's not the right tool for this job (if it were 16:9 it would already be installed). And, as the pictures show, with the extra IR, the Hik isn't too bad either.
his hikvision is a 6mm lens..that is why the fov is so small. His longse is 5mm.....Hey atom. Thanks for the review. One question. I don't understand why you say it would be better if it was 16:9. Looking at your screen captures, the Longse, even though it is 4:3, has a wider field of view. In 4:3, you get more top and bottom. In 16:9 format with the same field of view, you would have just lose the top and bottom. What am I missing?
Thanks.
Have you been able to resolve power issue? Does it reboot when it happens? I have not had any issues with mine, it's been recording non stop for past couple of weeks with no gaps, aside from when I was testing it.
As far as day IQ, it's interesting you don't see the benefits of the larger sensor. Hikvision images appear flat with slight noise, basically just like any camera with same size sensor. Although in landscape picture you won't see much difference.
Thanks.
