I emailing back and forth with support as 5.5.2.2 seems to have stopped DeepStack from working for me completely.
Got a message back from Support that 5.5.2.4 should fix the problem, and it has.
Out of curiosity, are you guys that re experiencing this running the CPU or GPU version? The reason I ask is because I haven't seen that behavior.
I've been getting the same thing.
Unfortunately not for me...Got a message back from Support that 5.5.2.4 should fix the problem, and it has.
I have a Nvidia T600 GPU. 5.5.2.4 went a long way towards fixing the problem.Out of curiosity, are you guys that re experiencing this running the CPU or GPU version? The reason I ask is because I haven't seen that behavior.
Hi sebastiontombs, I think there may be a misunderstanding - I also use rectangles instead of highlights. I only check the highlight box in the DS status window afterwards because its absence indicates the reason for cancellation. I’m trying to find out why, on the basis that it‘s merely used to give a visual indication and perhaps nothing to do with what’s going on in the software.Just my own observations. I don't use highlights, I use rectangles. They always seem to lag the target and I'm getting 99% detection with DS.
@Dave Lonsdale You may have seen it already but some useful information in relation to main- & substream motion detection & deepstack analysis in this thread:I have a Nvidia T600 GPU. 5.5.2.4 went a long way towards fixing the problem.
But I ask again if anyone can help me understand what’s going on:-
Referring to my second image above having the blue rectangle, from the help file it was cancelled because there was no highlight ”in which Blue Iris is attempting to match DeepStack objects”. However, if you simply look at the alert in BI instead of using the DS status window, at that instant it shows a red trigger rectangle. My understanding was that BI sends this image to DS for analysis followed by the additional images that we specify at 500mS intervals or whatever. So what’s the, “did not overlap areas where motion was detected” all about?
Is the highlight function somehow used to indicate how BI stops DS from analysing successive images when confirmation has been achieved? If so it’s screwing things up. And I always want all the additional images to be analysed to get the best one which is why I put an object in the Cancel box that will never be found (in my case “banana”).
5.5.25 fixes it for me (DS CPU version). The only issue I'm still observing is the yellow motion overlay is not added for analysis for the second sample (T-76msec) however object detection is processed as expectedBTW, .5 didn't fix it for me. A step back on my system.
As per the documentation, the motion highlight rectangle you find in the DS status window is used by BI to check if the detected object is related to the actual motion. If not (motion highlight do not overlap to detected object), alert is cancelled. I think this is used to mitigate false alarms due to static objects detection. For me this feature is disrupting.
There is no dependability also on those cameras where only the sub-stream is used. The behaviour is always the same.
Maybe an option to disable the overlapping check would do the trick.
