sebastiantombs
That's another thing that bothers me, but I didn't mention in my email to BI.  I thought, expected, that if a second video stream is found that both the main and substream fields would auto populate.  I guess not.
 @IAmATeaf - did you experience the BI turning on substream 2 or did it auto pull substream 1?
OK... had to experiment a bit and everything seems to be working right now. the Dahua PTZ (SD49225XA-HNR) was the only one NOT behaving properly with ONVIF triggering. Manually adjusted the auto-populated fields and I got it going....Yes, the fields are populated with the same "0000" digits. From what you're saying BI is detecting a stream that is not in use, already. I may give it a try with both substreams shut off and see what happens. I've had zero luck with anything after 5.3.4.3
