Refute my claim then. What did I say that was false? What could I know about it, I only have 3 systems with mismatched FPS between sub-stream and main stream and have no issues?Yeah, I think Ken said that, but what could he know about it, he only developed BI and keeps updating it.
That's why we're having this discussionI'm just commenting on the source of the information. You say you have no issues, but that's no issues that you see based on three systems. Ken is looking at thousands of systems and also looking inside the program. If you choose to use different iframe rates and it works for you, great.
, where a & should be in the Sub stream path. Other than that, unfortunately I have never set up a BI camera to pull trigger events from a camera so I am not sure what all is required. Perhaps your Discovery/ONVIF port needs changed to 80?You need to set the sub-stream parameters in the cam. Right now they are set to the same as the main stream.it shows as BI getting the stream from the substream, but with the same resolution as the main stream
Make sure Sub S is enabled in camera parametersHas anyone configured sub-streams for the Reolinks? 423 & 520. The main stream string reads /bcs/channel0_main.bcs?channel=0&stream=0&user={......}
If I add 1 for where there's a 0 the camera doesn't show; if I just replace the 0 on stream I get both main & sub streams identical.
My SV3C is working ok (so far)....
CPU showing 30-35% RAM 1.08G
Sorry, I can't find that setting.
He’s saying to ensure that the substream is enabled within the camera itself.
Sorry, the Sub stream needs to be enabledSorry, I can't find that setting.
